Continental 17" runflats and gravel roads
The set of run flats drives me crazy and above 120kpu one can hardly have a conversation in the car, a 2015 C180 Exclusive.
These tyres have done approx 25K and honestly i cannot endure the road noise anymore.
What alternative brands can you recommend which will have the least road noise?
Frankly - depending on you wheel-size, tire-pressure, and drive style you could be at the last 25%-30% of tread life... and YES going into the last 25%/30% especially on Extended Mobility tire things will be noisier, harsher, and less enjoyable.
YES - you will probably benefit a lot from moving forward to fresh tires - I choose "regular" tires as I have not had flat tire issues and carry a can of flat-fix.
I have 18K miles - 29K km - and have over 50% tread left on a decent set of "regular" tires.
Cannot give you recommendation since tire brands and tire style names in a particular brand etc are all entirely different between US and SA - here in US there is a UTQG "treadwear rating" where higher the # the longer that tire is expected to last (at proper MB recommended tire pressure) - the lower the # the intent is that will be a "stickier tire" (softer rubber) and less treadlife.
