2016 C300 Audio20 Center Dash Speaker
I replaced all of my stock speakers with component or coaxial speakers (Match Audiotec-Fisher). Huge upgrade! I notice that there is a speaker in the center dash but no sound is being sent to it. I assume this is for the MBRACE system. I'd like to update that speaker and use it as an additional speaker similar to how the Burmester system does. the replacement speaker has dual imputs: one for the audio system and one for the MBRACE system. Is it possible to use this as an audio speaker with the Audio20 system without re-wiring the whole system.
Did you just upgrade the speakers only of did you do an amp as well? How difficult is it to access the speakers to replace them? I'd like to know more about what you used and maybe a ballpark as to cost. Thanks
This link takes you to the Fischer/Helix/Match speaker page - the OP I "think" upgraded his Audio 20 - fronts with mid/tweeter/crossover replacements - and rear doors w/coaxial"
https://www.audiotec-fischer.de/en/match/speakers/
Fronts mid/tweeter/crossover about $270: https://www.ebay.com/itm/Match-Audio...-/233306655431
Coaxial Rears about $220: https://www.ebay.com/itm/Match-Audio...4AAOSwl8ZdST-~
Only the speakers... if you go to the Crutchfield website and enter you car make/model the Match (Auditec-Fisher) direct replacement speaker will show. Note: the component (tweeter seperates) will need to be wire-tapped to the existing front door 100mm (4inch) speakers. I suggest that rather than using four coaxial speakers.
