Thinking about vacuuming your oil? Here's what I've used.
Old Jan 15, 2020 | 10:12 AM
mikec35's Avatar
2016 C300 sedan
For those of you wondering which pump to get I thought I'd post my experiences with a couple to help you make a decision.
I've used 3 different ones, the most recent one is the best but it also cost the most. First was a $20 electric pump, it didn't make it through the first oil change.
Second was a manual pump, it worked fine but only lasted about 10 oil changes. You have to empty it once in the middle of the change process and pump it probably 60-100 times during the entire process. This one cost $50.
Most recently I purchased this one from Harbor Freight. You can use if for a few oil changes before you have to empty it. This is the best one so far, just use your compressor to fill it with air and walk away. You may have to add air one time after the initial air charge. The nice thing about this one is that you don't have to babysit it. I did have to use the small hose from the first $20 pump I listed as the Harbor Freight one didn't have a small enough diameter hose to work with the Mercedes dipstick tube.
I also considered a couple of manual oil pumps but decided on the pneumatic since I do about 6-8 oil changes a year. I got mine for $128 using a 20% coupon.
Old Jan 15, 2020 | 12:10 PM
Wfrager's Avatar
2019 GLA 45 AMG
I've had a couple of those cheap electric pumps. Very messy. I now use this:
https://www.amazon.com/gp/product/B06WD64H8Z/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B06WD64H8Z/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Old Jan 18, 2020 | 07:09 AM
Pope_RW's Avatar
C300
Originally Posted by Wfrager
I've had a couple of those cheap electric pumps. Very messy. I now use this: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Just from the specs listed on amazon, this appears to hold less volume than the sump contains, do you empty it mid oil change?
Old Jan 18, 2020 | 07:58 AM
Camaroguy72's Avatar
2019 GLC300, 2017 E300
i use the mityvac 7201.holds over 2 gallons and a really nice unit.
Old Jan 18, 2020 | 11:39 AM
fred9x's Avatar
2019 GLC300 4matic
I use Topsider. It holds 2 gallons and I did not have to empty it mid drain.
Old Jan 18, 2020 | 12:03 PM
Pope_RW's Avatar
C300
I'm clearly referencing the quoted post
Old Jan 18, 2020 | 12:42 PM
fred9x's Avatar
2019 GLC300 4matic
Pope_RW,
Yes I agree with your post.
I was replying to the OP's comment about the Topsider.
