Driver side window squeak
Old Feb 9, 2020 | 10:35 PM
jkhjr's Avatar
2016 C300
Solved
Old Feb 9, 2020 | 11:04 PM
Tyler Hall's Avatar
2015 c300 Sport
My car does the same thing, it’s in the door panel itself, I’ve taken it off multiple times trying to find a solution just can’t seem to pin point where the noise comes from, very annoying
Old Feb 10, 2020 | 11:04 AM
jkhjr's Avatar
2016 C300
Solved
Old Feb 10, 2020 | 02:18 PM
GringoBling's Avatar
C400
put dielectric grease on the rubber seals, and also the weather stripping that is on the outside where the rubber means the external body.
I've tried it all, and this is the only thing that works. It's an old Corvette trick.
Old Feb 10, 2020 | 02:26 PM
jkhjr's Avatar
2016 C300
Solved
Old Feb 11, 2020 | 01:54 PM
stockbmw's Avatar
2018 C43
Had this problem on day 1 when I picked up my car. All they did was spray some lube into the window seal inside the door and noise hasn't came back.
If your car is still under warranty, go back. If not spray some wd40 but best to call them and ask what spray it is.
