NO COMMUNICATION WITH ECM AND ISM/TCM
Hi
hoping someone can shed some light on this problem.
i have a w205 c250 cdi. Car starts with eml light on. After a min or two car remains running and dash shows all warning lights. At this point cant communicate with ecu and tcm. Once the car has been switched off it wont turn on again untill battery has been disconnected overnight. All warning lights stay on and it says without changing gear consult workshop. I can communicate with other modules which say no communication with ecm and tcm. I have checked all wires and fuses but cant seem to communicate with either of the modules.
Ahmad Khalaf (05-14-2021)
Hi
I hope you solved the issue. I have same issue with my 2015 c300. Error in communication with almost with all Drivetrain components ecm tcm ism . Checked all fuses and checked if there's any corrosion but all seems to be intact and no issues with the fuses. Hopefully you can direct me to the right area to start with. Thanks
joubaie (05-13-2023)
i have a similar problem with w205 c300 4matic i have no communication with drivetrain ecus (tcm,ism,ecm,drivetrain) no communication and the gear level doesnot appear on instrument cluster .i check can bus all good and no corrosion engine ecu is replaced still no change
Hi
