Imjector problem
Old Feb 24, 2020 | 03:42 PM
Paul Netherton's Avatar
c220 cdi sport
Imjector problem
Hi
I had a problem with my W205 220cdi 2 injectors were leaking and there was a build up of carbon which was bad, I replaced the rocker cover cleaned all injectors and the shafts. Put 4 new merc seals and bolts and was fine for a month or two. one injector started leaking again so I took it out cleaned it up. Brought another seal and stretch bolt from merc dealer fitted the injector and was fine for a month or so and started leaking again. Can anyone assist me with an answer ?
Thanks in advance Paul
Old Feb 24, 2020 | 04:27 PM
Andy74's Avatar
W205 2015
My advise to you is to stop waisting your money. This a serious problem: the injector is leaking. Let your local dealer check it and let them fix it once for all. If the same problem came back again the dealer must fix it for free.
Old Feb 24, 2020 | 04:53 PM
GringoBling's Avatar
C400
replace the injector!
Old Feb 24, 2020 | 05:25 PM
c220 cdi sport
think if i replace the injector it will leak again as the injector is working fine but its like the seal fails and starts leaking wondering if its the thread in the stretch bolts
Old Feb 24, 2020 | 05:26 PM
c220 cdi sport
its not leaking fuel the seal fails and carbon leaks
