New "Midline" audio option - how to get signal?
2019 C300D Estate
Hi,
I've been lurking for some time and have lapped up all the threads on W205 audio, including the "Burmester" and "Audio 20" upgrade blogs (thank you Mike, invaluable!)
I assumed I had an Audio 20 system and ordered bits accordingly, but now I've found an amp in the boot trim (RHS) marked "Midline"
This would explain the centre dash speaker where there shouldn't be one - there's a new "mid range" audio trim between the A20 and the Burm, and it has an amp.
Does anyone please happen to know whether I can still get a high-level feed from the Quadlock in the dash, or whether I have to T off the high-level outputs of the amp a la Burmester?
Assuming the latter (1) does anyone want an unused Audio 20 / Mosconi 90.6 loom and (2) does anyone have access to a pinout diagram for the Midline amp please? I'm guessing its not the same as the Burm - that would be too easy.
Its one of these: https://i.ebayimg.com/images/g/kewAA...KC/s-l1600.jpg
Cheers
Alex
Cheers
Alex
Hi,
Cheers
Alex
Cheers
Alex
did you ever manage to find a solution to this? Did you manage to get a signal from the midline amplifier ?
cheers
carl
