Kazoo Noise when accelerating (video)
Hi everyone,
I have a 2015 C300 sedan base, when I am driving and I give the gas a nice push there is a kazoo like sound that comes out. I have recorded a video and was hoping someone knows what is causing this! Thanks in advance
LINK:
LINK:
Juan Reyes (04-09-2020)
Yes, here in NA. Took my c300 for a ~120 mile drive, had it on sport+ and everything was fine. Once I get to my destination it started making this noise. Only when I’m accelerating pretty fast, does not make noise if I’m accelerating moderately
Take it to the dealer, especially if you have any warranty or extended warranty left.
Yup what the other person said. That car has a turbo right? That definitely sounds like a boost leak coming from intercooler piping somewhere. Probably a clamp on one of the piping got loose and it leaks since it's under pressure while accelerating. That's what it sounded like on my last car.. Kinda sounds like a choo choo train 😄.
A boost leak test will need to be done.
NA in his question means Naturally Aspirated, i.e. non-turbo. Your engine is turbocharged. There's a leak and you're hearing that noise when the turbo spools up and increases the volume of air coming through.
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
I'm taking it to get it looked at. Is this something that can be done at home though? Not really into fixing cars, most I've done is change the cabin air filter and clean the evaporator coil lol
The boost leak would be coming from one of the the "charge pipes", either going from the turbo to intercooler, or from intercooler to throttle body on the intake manifold of the engine. I suppose it could be possible that a vacuum/boost hose is also off but then I am confident that you would get a CEL for that.. So any clamp in-between the turbo and throttle body would be the suspected areas to look at first. See if any are noticeably loose - but keep in mind they can appear tight but still leak once turbo boost pressurizes the system... Also see if a pipe does not look like it is connected completely flush to the turbo, intercooler or throttle body which could be a sign of the leak as it could have pushed it out of place a bit when it leaked..
If none of the above, perhaps one of the pipes or the intercooler itself has cracked and has a leak, In which case you need to have it replaced.
If you take it into a shop they will likely just do a boost leak test to pinpoint where the leak is. Which they will disconnect the air intake and connect an air compressor setup to the turbo, and slowly pressurize it to hear where it is leaking from.
EDIT: but honestly, if this is out of your comfort zone to troubleshoot it would be best to just take it in.
BayAreaAMG (04-23-2020)
