Center Console Removal - Stuck?
When placing the center console back though, somehow it got stuck. The console appears to be in place, but the bottom two screws are not aligned. I peeked behind the top, and the two clips aren't clipped behind the dashboard. See photos for a better visual. I cannot remove the console now, no matter how hard I try. I spent a good 20 minutes trying to remove it, as well as trying to just push with all my strength to get the clips to pop in. It seems stuck from the bottom area where the touchpad is.
Any thoughts?
Maybe a gentle push forward (using the touchpad tower) towards the dashboard while simultaneously lifting that end up? Just be careful not to push too hard forward.
You could a trim removal tool that you squeeze the handles together.
Something like this.
This hook should go under the dash.
Haven't fixed the console yet, Im taking it to my local shop and see what they can figure out. With the amount of force I tried taking it out, I dont want to break anything.
