TPMS says one tire has 0 psi; gauge reads 40 psi
Old Apr 26, 2020 | 04:50 PM
eddieo45's Avatar
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe; daughter: 2017 GLC SUV
So my wife hasn't driven her C300 at all for a few weeks, what with the clampdown and all, but she ventured out the other day for a quick errand. A few hours later, we decided to use her car for a weekend trip, and when I started it the TPMS warning was on. She said she had seen it earlier, and it was only off a pound or two. You know it won't read values until you drive for a few minutes so I grabbed my compressor just in case and set off. At the end of our street the alert turned red and it showed 0 psi in the right front, 40 psi everywhere else. She has 17" wheels so not low-profile at all, and tire looked fine, but I fired up the compressor anyway and as soon as I connected it the analog gauge showed 40 psi. I'm assuming a bad sensor but I've had many TPMS issues on other models and I've never had one read 0 psi, though I have had older models where it just said "no connection" or something similar. Car has about 65,000 miles and the front tires were replaced about a year ago (FYI, I swear the rears are original!)
Old Apr 26, 2020 | 06:06 PM
diamondsilver16's Avatar
2016 C300W4 (W205), Luxury Pkg, Diamond Silver Met. and Silk Beige\Espresso Interior
The TPMS sensors in the wheels are battery operated. They have CR2032 lithium batteries that have a lifetime of about 5-6 years before they need to be replaced.
The batteries are integrated (soldered) into the unit, so they are usually replaced outright with a new unit in the wheel and programmed into the system by the installer.
Old Apr 27, 2020 | 07:07 AM
eddieo45's Avatar
Would you think that means the remaining three will go soon as well?
Old Apr 27, 2020 | 11:37 AM
allanyeung99's Avatar
2017 Mercedes C63s
I would change all four since one is going bad, they will eventually go bad soon so might as well get them all change at one time.
Old Apr 27, 2020 | 01:29 PM
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
Try driving the vehicle for a while until the PSI values show again (on the three tires), then press the down arrow and set the reference values. TPMS will restart/reboot. (See if that fixes it)
If that works, reset the reference values again to proper PSI numbers.
Old Jul 23, 2020 | 06:34 PM
eddieo45's Avatar
I never saw this, and I wish I had: benzdude always has great tips. I eventually called the dealer and arranged contact-free service. They actually recommended replacing only the bad one, saying they sometimes "last forever." They sent a valet to the house with a loaner that arranged over the phone. I left the key in the car and they took it, leaving a key in the loaner. So the SA calls me and says they want to a diagnostic scan on the car to see what's wrong, cost $160. I said, "the MFD is telling you what's wrong, isn't it??" It got a little testy and he said "I hear your frustration..." I told him to do whatever he needs to.
It was a bad sensor, which they replaced, $124.48 for the part, $161.81 for labor, $21.48 "miscellaneous charges", total after tax $316.89 I've paid $80-$100 many times at a neighborhood tire shop (generic sensors) so I figure this is just about right for the MB OEM exchange rate. Oh, he waived the diagnostic charge!
