HELP!!!!
Old May 19, 2020 | 01:33 PM
feebabii's Avatar
2017 c300
HELP!!!!
Hi guys I’m looking to convert to diamond amg grill A2058881260 with the star A0008881000. The problem I’m having is the star for some odd reason isn’t fitting and won’t snap in correctly there isn’t any damage parts.
If possible can you guys help and guide me in the right direction???
Thank You in advance!!!
Old May 19, 2020 | 07:46 PM
Andy74's Avatar
W205 2015
Please provide more details. Is your car AMG line or classic? I assume​ we are talking OEM? Did you buy them both from the same seller? I bought diamond oem grill and this glass distronic star. They fitted. My car is an AMG line.
Before
After
Old May 19, 2020 | 08:36 PM
irondad's Avatar
W205, X253, C190, W213,
The parts you listed are both OEM parts and should fit. Are you aware that the star twists slightly in a clockwise direction to lock in place?
Here's a short video that shows you how it fits:
Old May 19, 2020 | 08:51 PM
Andy74's Avatar
W205 2015
[QUOTE=irondad;8060189]The parts you listed are both OEM parts and should fit.
I have seen many aftermarket parts with oem parts numbers on them.
Old May 19, 2020 | 09:02 PM
irondad's Avatar
[QUOTE=Andy74;8060198]
That would be what's called the "interchange part number" and not the manufacturer's part number. Regardless...the number is irrelevant and the installation is still the same as I explained. Hopefully that information can help OP eliminate that as an issue.
Old May 19, 2020 | 09:27 PM
Andy74's Avatar
W205 2015
[QUOTE=irondad;8060211]
I am not sure why its not fitting. Usually aftermarket parts have less restrictions compared to OEM parts.
Old May 19, 2020 | 10:21 PM
feebabii's Avatar
2017 c300
They are both oem parts I have a 2017 c300 non amg but I’m changing my grill to the diamond grill and bought both pieces from different sellers. I contacted the seller of the star and his star is from a 2019 c43 he said it was on the horizontal grill. I’ve checked all videos and tried everything but still won’t fit
Old May 19, 2020 | 10:29 PM
feebabii's Avatar
2017 c300
Before
After
thats the same star I have but it won’t fit and they are both oem
Old May 19, 2020 | 10:39 PM
Andy74's Avatar
W205 2015
Nope, the facelift and prefacelift stars for the C43 are not the same.
Your diamond Grill is prefacelift and your star is facelift. The star wont fit.
Old May 19, 2020 | 10:41 PM
Andy74's Avatar
W205 2015
Nope my star is prefacelift. Your star is facelift. They are not the same.
Old May 19, 2020 | 10:45 PM
Andy74's Avatar
W205 2015
Try using your existing stock star on the diamond grill and see it it will fit.
Did you install the diamond grill on your car?
Old May 19, 2020 | 10:47 PM
feebabii's Avatar
2017 c300
ok got it thanks I didn’t even know. I haven’t installed the grill yet, I was going to check to see how much the dealer cost to install it. I’ll more than likely just use my star on my stock grill
Old May 19, 2020 | 11:08 PM
Andy74's Avatar
W205 2015
The reason why I was asking to see if you already installed it is because as far as I know the OEM AMG products such as the C43 diamond grill only fit on AMG or AMG line models. I hope I am wrong.
Old May 19, 2020 | 11:18 PM
feebabii's Avatar
2017 c300
oh wow really. Do you know which ones fit the regular c300?
Old May 19, 2020 | 11:44 PM
Andy74's Avatar
W205 2015
Please give your dealer a call first and ask if it will fit on your car. If the answer is no then I recommend you check Ebay there are plenty of aftermarket diamond grills that can be installed on your car. Get the seller to confirm it will fit before you purchase.
Old May 19, 2020 | 11:50 PM
feebabii's Avatar
2017 c300
Thank you so much Andy appreciate all your help!!!
Old Nov 20, 2020 | 06:07 AM
Malinois's Avatar
w205 w460
Hello,
And what diamond grill number for a A0008881000 facelift star?
Also A0008881000 is coming as a complete set of black backplate and star?
Thanks!
Old Nov 20, 2020 | 11:56 AM
Shoaib R. Manai's Avatar
Mercedes C300 2015
Originally Posted by Malinois
Hello,
Thanks!
I just ordered this part, will be here in couple of days. I will report back, however, its for preface lift one.
