New set of tires
Old Jun 29, 2020 | 05:49 PM
dtd's Avatar
dtd
2017 C300
New set of tires
Hi All,
I'm at 28000 miles with the OE Continental tires. I need some advice on a new set of tires. Should I stay with the same OEM or get new brands.Thanks,
dtd
Old Jun 29, 2020 | 07:34 PM
stockbmw's Avatar
2018 C43
Stick with OE run flats if you are happy with current setup without spare tire or tire pump kit. Else, Michelin pilot sport a/s3 for all season or pilot sport 4s for summer only, but you would need something incase a blowout like tire pump kit, spare tire or roadside assistance.
Old Jun 29, 2020 | 07:40 PM
dtd's Avatar
dtd
2017 C300
@stockbmw, thank you, would you consider Bridgestone Drive guard from Costco? I am O.K with Continental, if I stay with it, I have to buy from the dealer, I would like to try out Michelin Primacy 3 RF.
Old Jun 29, 2020 | 10:35 PM
Mikey53's Avatar
Veteran: Air Force
2016 C300 4Matic traded in for a 2022 E450 Coupe
Continental Extreme Contact DWS06. Check ‘em out
Old Jun 29, 2020 | 11:58 PM
irondad's Avatar
W205, X253, C190, W213,
I'm in the Michelin Pilot Sport a/s3 for all season or Pilot Sport 4s for summer, camp, and have had each on my different MBs. They transform the car.
Old Jun 30, 2020 | 12:40 AM
dtd's Avatar
dtd
2017 C300
I really like to try those tires but they are not RF, are they? So, no one recommends Bridgestones.
Old Jun 30, 2020 | 12:43 AM
stockbmw's Avatar
2018 C43
Most of recommendation will be non run flats on here because RFT basically sucks bad. They break your rims and puncture on small pebble.
If you are satisfied with your current setup, best to stick with it.
Old Jun 30, 2020 | 02:45 AM
diamondsilver16's Avatar
2016 C300W4 (W205), Luxury Pkg, Diamond Silver Met. and Silk Beige\Espresso Interior
I'm 12k miles in on these: Sailun SH406 All Season
Great traction both dry and wet (no snow CA). Even wear on both front and rear with rotation at 10k miles.
Old Jun 30, 2020 | 07:56 AM
dtd's Avatar
dtd
2017 C300
@diamondsilver16, so your car has 17 in wheels? That's why you can rotate, mine has 18 in wheels and i can't do that since front and rear are different in size. However, they wear out evenly. Continental is O.K so far. RF tires are convenient but the selection is limit.
Old Jun 30, 2020 | 02:15 PM
@diamondsilver16, so your car has 17 in wheels? That's why you can rotate, mine has 18 in wheels and i can't do that since front and rear are different in size. However, they rear out evenly. Continental is O.K so far. RF tires are convenient but the selection is limit.
Yep, stock 17's. I ain't fancy
Old Jun 30, 2020 | 02:20 PM
dtd's Avatar
dtd
2017 C300
Actually, I like 17in wheel better, since the 18 in wheels have a low profile, so the ride is bumpier than the 17 in one. Just my guess.
Old Jul 1, 2020 | 03:04 PM
jevsays's Avatar
2016 C450 AMG, 2005 C230 Kompressor
I'm currently riding on DriveGuards. No issues thus far (almost a year to date). I have heard numerous times the PS4S is life-changing for our ride so may make the switch eventually when these wear out.
Old Jul 1, 2020 | 08:12 PM
dtd's Avatar
dtd
2017 C300
I always like Michelin, but I need RF tires for the W205. I don't want to add more stuff in my trunk. I may buy the Bridgestone Drive Guards from Costco. Did you have 4 wheel alignment from the dealer or somewhere else?
Old Jul 3, 2020 | 08:43 AM
jevsays's Avatar
Purchased and installed at Discount Tire - check for July 4th discount sales and rebates. I have a friend that was the manager there for a few good years so I trust him and his crew.
I was cruising in the hill country yesterday and handled corners well, I'm sure not as sticky as PS4S. Ride is smooth, yet bumpy/harsh at times (speed bumps, etc) which should be expected for RFT.
Old Jul 5, 2020 | 01:06 PM
Drewwskii's Avatar
2015 C300
I just put these on in combination with 19 inch wheels for summer about a week ago. It's a little early to tell but so far so good
