Steering wheel column noise
Old Aug 26, 2020 | 03:43 AM
quduoheng's Avatar
a45
The steering wheel makes a loud bang when ignition on every morning(or parked for over an hour).
Appreciate any suggestions. So I can be more specific when bring it to the dealer. Thanks.
https://www.youtube.com/watch?v=KLtE...ature=youtu.be
Old Aug 27, 2020 | 10:11 AM
blizzard12's Avatar
2017 Mercedes-Benz C300, 2017 Mercedes-Benz GLC300
The video is private, cannot watch. Anyway, try disabling "Easy entry" in Car Settings and see if you still get the "bang".
Old Aug 27, 2020 | 01:45 PM
bzammitt's Avatar
2015 Mercedes C400
Had the same problem, rubbed/caught on something during easy entry. Disabled it and haven't looked back since lol
Old Aug 27, 2020 | 11:55 PM
quduoheng's Avatar
a45
The Video should be up now.
You are right, disabling the Easy entry will not create that "Bang" because the height adjustment motor is not moving.
Old Aug 28, 2020 | 12:02 AM
quduoheng's Avatar
a45
Sounds like it is the case, the Bang is more like mental rubbing. I guess not adjusting ing the steering wheel that often is the solution.
Other owner who got the same problem had the dealer changed the adjusting motor. I double my dealer would do that for me LOL.
Old Aug 28, 2020 | 09:12 AM
blizzard12's Avatar
Having watched the video I can confirm that it's the steering wheel height adjustment mechanism. I've heard the same noise on multiple C300s. The older the car was the louder the noise was. Basically those are moving parts and some wear occurs over time. The more it wears the louder it will be. I have disabled mine.
The only time when "Easy entry" was really useful was when my wife was pregnant. Other than that I just find it a fancy feature that I don't really need.
Old Aug 28, 2020 | 02:52 PM
GringoBling's Avatar
C400
my C400 did the same, its just how it is.
Old Aug 28, 2020 | 03:35 PM
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
I have that same issue (noise) and an extended warranty, so I might get it fixed or maybe add some grease?
Old Aug 29, 2020 | 01:53 PM
quduoheng's Avatar
a45
depends on if you have a good relationship with the service advisor.
I don’t think any grease will fix the noise from metal to metal contact.
Old Sep 1, 2020 | 10:29 PM
redsly's Avatar
2016 C450 (gone), 2018 GLC43 (gone), 2020 GLC43, 2012 ML350, 2013 E350
Not sure if it's just the video, but I've never heard one quite that loud. You can try to lubricate/grease the height adjustment drive 'screw gear'. Be sure to lubricate between the metal brackets /stops and the plastic bushings/washers.
When the height adjustment raises to its end stop point, it can actually put too much pressure on it before stopping (the teach-in for the range of adjustment uses current to determine stopping points) and causing the excessive force required to move it down... Causing a sudden harsh movement and this noise upon releasing.
There may be an LI document for this, but off hand I'm not sure if your car is related to it. It basically says to check the version of height adjustment drive mechanism that is installed and to update the driver seat control module. Which, will teach-in the height adjustment range based on new software specifications.
If not covered under warranty, you can try the above and see if it helps.
