Remove cable door wiring
Old Nov 6, 2020 | 02:23 PM
why0L's Avatar
C400 4Matic 2014
Hello,
I need to route 4 cables through the front door wiring harness connector.
But I think to push them in, I need to remove the long purple spacer.
Unfortunately, the black thick cable is blocking it (I think it's the fakra).
Any ideas how to remove the black cable?
Already removed the small purple spacer on the side, but the cable still won't come off...
Will upload photos in couple minutes..
Old Sep 8, 2021 | 01:15 PM
wei1221's Avatar
VOLVO V60
To share with you, you must push this away.
Old Mar 31, 2022 | 05:04 PM
Zunages's Avatar
W205 AMG C43
I would like to add additional wires to connect my aftermarket sound speakers in the front doors
i plan to use free sockets (i dont wint make any additional holes)
Witch pin teeminals should I use (partnumbers) ?
W205 c43 2018
Old May 8, 2022 | 04:41 AM
guytoru's Avatar
w213(S213)2017y
Hello,
How do I un-plug(remove) wiring harness passenger-door w213.
(I think it's the same as the connector for this thread.)
The harness on the vehicle body side could be removed.
But the harness(connector) on the door side cannot be pushed inside the door.
I don't know if I need to pull out the red part inside the connector.
Please tell me how to safely remove the connector from the door.
How do I un-plug connector ?
Old Jul 4, 2022 | 01:33 PM
Wail Faridi's Avatar
Mercedes W205
Did you figure it out? I need to remove the connector on the door side as well, but I just couldn't figure it out.
EDIT : I found a video that shows how to do it. You basically need to pull the red tab forward in order to completely remove it, then you'll be able to press down the tab on the top of the black connector and push it into the car. I'll leave the link for the youtube video.
