So after considering putting the factory static led headlights in I figured it was too much trouble since coding was needing. Because of that I have decided to do a retrofit to the factory halogen headlights. I知 doing dual projectors with demon eyes and switchback projector shrouds, sequential turn signals in the lower lense. I plan to do away with the factory drl led and have it running just halos. I知 wanting to have all 4 projectors running low beam/ high beam function. I値l have the demon eyes hooked up to a switch and plan to have some red leds in the grill emblem as well for just picture and show lights basically. About to gather the parts up and will keep updated on build process, going to take some time with the canbus system but it値l be a one of a kind build and first that I致e seen. The light out put with 4 projectors will have a clean cut off line to focus the light well and the light out put should be amazing between 4 projectors and hid system.
