Please help...Oil Leak from oil filter housing 17 C300
A
Changing the oil is usually a very straight forward process. I usually do it after a drive, get it to operating temperature, and then let the car cool off for 30 minutes. Maybe this helps the plastic cap loosen up easier? I don't know. If the cap was tight (from previous owner/dealer) I would have first used a breaker bar to help get it loose. I've tightened it snug always from my past 4 oil changes.
So the old oil filter cap is for sure destroyed based on your story... here's the part number 270-180-04-00. #13 on diagram. I see as low as $39 or regular price $52 for one.
If you stripped the metal threads inside #2 while destroying the plastic housing cap and it's not keeping a good seal anymore sorry man, looks like #3 might have to be replaced. That's as low as $390 and regular $520. Plus you got to deal with the vibration damper that looks like it rolls around with the serpentine belt.
FYI...the threads that are bent are in the metal part that the cap screws directly into. So the thread sealant is on the threads of the cap.
