P06DA code - oil pump solenoid
With good oil pressure disconnecting will avoid a problem if it ever gets stuck close, yes?
the solenoid is activated (to close) when ECU calls for it and will open in default state like when engine is off when there is no communication. The worry is, it could get jammed by debris. Hence why it is recommended to unplug it. So if oil pressure good, recommend just unplugging it and if you are worried about a check engine light, you can plug a dummy solenoid OUTSIDE the engine and zip tie it somewhere safe.
the solenoid is activated (to close) when ECU calls for it and will open in default state like when engine is off when there is no communication. The worry is, it could get jammed by debris. Hence why it is recommended to unplug it. So if oil pressure good, recommend just unplugging it and if you are worried about a check engine light, you can plug a dummy solenoid OUTSIDE the engine and zip tie it somewhere safe.Well, to explain it in a simple manner, the engine uses two pressure modes, which is why it is called a two stage oil pump solenoid. At high RPMs, the solenoid disconnects which results in the normal oil pressure mode. At idling or low RPMs like below 2000 for example, it is in low pressure mode which the ECU tells the oil pressure solenoid to close. Disconnecting it allows the solenoid to always operate in normal oil pressure mode regardless of RPM. This results in better responsiveness, less chance of scoring, less heat to the pistons and way more benefits. For more details, please see the big thread linked previously.
Think of the opportunities! Some stranger on the internet blow up his Mercecedes (Faaaaannnnceeeee Yuppy car). So, then we get to see the engine for us all to learn!
https://www.youtube.com/@I_Do_Cars
