W205 Summer rims Width/Offset
Old Feb 28, 2021 | 06:47 PM
Nikola Jovic's Avatar
2015 W205 C180d (OM626)
Hello,
I've found some rims that I would like to use for a summer set of wheels. Currently, I'm using OEM 17" rims with the winter tyres on. I'm planning to buy some set of 18" rims, and I've found one set that I like (Momo Revenge). The problem is, 18" rims from factory have width of 7.5" and offset of 44mm, and same or 8" and 56mm for the rear, whereas those rims that I've found are all 8" and 43mm (they were on W213). Does anybody have an idea whether those rims will fit, since I have to travel across a country to actually try them ?
From some documentation, I've found that Brabus wheels are wider and are protruding more both inwards and outwards on both axles, so I'm thinking that there should be no problem, but I'm asking just in case, since I've not found this combination anywhere.
I drive W205 c180d.
Thank you.
Old Mar 29, 2021 | 06:59 AM
I have put 18" et35 8j, there's no problems.
