C350e check engine light - P1D03 P1D01
https://www.autocodes.com/p1d03.html
Hey guys,
I have just done a quick test on my car with an OBD reader after the check engine light came up on my c350e a couple days ago.
The above stated codes are showing up on the faults. Can anyone point me in the right direction, where to start looking and troubleshooting? The links above don't give me enough information.
Any help would be greatly appreciated. I did do a search on the forum but didn't seem to find anything helpful in my situation.
Thank you!
om new to this tread I wanted to help or heads up on a issue I have with me car
C350E
When I start the car or seems normal for a few mins. Then it will jerk and a message will come
up
MALFUNCTION
Can anyone advice share any knowledge or first hand experience on this please
Also when your CEL came on, did it stay on? Mine came on once but after a restart it cleared. When I pulled codes, there were none.
Sorry I’m failing to understand how it could be the starter motor. I’m confident you speak with experience of this but it’s just me I just don’t get it. May I also kindly ask did your have this problem and if so had it been sorted ?
it seems my hybrid system is playing up. If I drove with eco mode/hybrid it seems to be charging it self when before the issue that never used to happen. Regards
it happens on both eco mode and comfort mode while on hybrid modern matter what mode i do it happens
i start the car
drive for about 10,30 seconds sometimes longer and then the message appears and the jerk kicks in
