Subwoofer amp install
Old Mar 7, 2021 | 03:22 PM
venerc300's Avatar
2015 C300 4matic
Hello this is my first forum question and i got no other resource to get answer to my issue but any input is appreciated thanks in advance..
I’m installing sub and amp to my 2015 C300, and I tapped wires to the 2 speakers on the top back seat to the rca to high level inputs of the amp, btw it’s a Kicker dx250, but no sound on subwoofer, i used another source to the rca input and then sound came out, i looked at YouTube and the stock radio doesn’t have rca preamp out, so i used that speaker to tap, so i don’t know why it didn’t work, does anyone got advice what to use to connect to amp input, thanks
Old Mar 7, 2021 | 11:09 PM
16C300base's Avatar
2016 C300 base
I Did the same thing initially, but my amp wouldn't consistently turn on. I ended up purchasing a line level converter which had a remote wire output. Amp and sub work fine now with factory audio 20 system
Old Mar 8, 2021 | 12:38 PM
PaulR7's Avatar
W205
Subwoofer is wired in pair through front left positive and front right negative pair on the original connector so that's probably why it didn't work.
https://w205audio20.wordpress.com/ for more reading.
Old Mar 9, 2021 | 01:13 PM
venerc300's Avatar
2015 C300 4matic
So I bought a line level converter and still didn’t got any sound output, I removed the converter, so i ended up tapping line to left and right door speaker, sounds came out but the loudness is not that great as I thought it should, i did some adjustments but it didn’t do as loud or boomy as expected
Btw mine is Burmester sound, does it have something to do with it?
Old Mar 29, 2021 | 02:31 PM
Cyoulater's Avatar
M271 W205
I just did mine yesterday
I followed this as he was the only one who posted the colors for the wires to tap into.
I used an LOC instead of the gadget he used and tapped into fuse 447 i think which is the 12v rear - switched
