Rear brakes DIY question
Old Mar 20, 2021 | 05:06 PM
pkaia524's Avatar
2015 C300 4Matic, 2014 Porsche Cayman, 2017 Porsche Macan
Tried to replace my rear pads today. No problem putting the caliper piston in “Fitting” mode. The problem is I could not fit the caliper/piston around the new pads no matter what angle I tried. Amy tricks I should know?
Old Mar 20, 2021 | 05:29 PM
chassis's Avatar
2017 GLE350 4MATIC
Did you compress the caliper piston fully back into the caliper? Which tool did you use? Please post a photo of the tool. Thanks.
Old Mar 20, 2021 | 07:29 PM
pkaia524's Avatar
Normally I would either use a typical piston compressor, or put a pad back in the caliper and use 12” adjustable pliers to squeezer the piston back into the caliper. But not this time. I am concerned that since it’s part of the e-brake mechanism and so connected to a motor, screw, etc I’m worried about damaging that motor. So I didn’t use any tools.
Old Mar 20, 2021 | 10:51 PM
chassis's Avatar
2017 GLE350 4MATIC
You need to compress the piston back into the caliper. You need a tool. The Lile tools at, for example, Pep Boys, work well.
