How to disable stability?
Old May 10, 2021 | 11:29 PM
Tyler Hall's Avatar
2015 c300 Sport
So with all new performance mods I had to put them to the test on the track. Ran into an issue, dyno mode is awesome but since Mercedes uses electronic lsd it disables that as well which means one tire fire! Turning just traction control off still has stability control which kills power when it spins so much. Any way around this? Can I pull a fuse? Was hoping it’d be easy to just wire a switch to a fuse
Old May 11, 2021 | 07:06 PM
AzurSL's Avatar
1986 Light Ivory R107 560SL & 2024 W206 Starling Blue C300 4MATIC AMG-Line, Exclusive Trim
Not sure, I was planning on trying out dyno mode after finding out how to use it, but didn't realize it also shut off the electronic lsd, so that sucks. I have heard of people pulling fuses on mb's to disable tc, not sure if it also disables stability control as well or if there is another fuse for that. I'm definitely interested to see if other members have found a solution to this.
Old May 12, 2021 | 12:59 AM
Tyler Hall's Avatar
2015 c300 Sport
yeah it really sucks, I’m going to try a fuse this week if i get a chance and see how it does. Goal is to find a fuse and run a switch to it to make it easier to disable
