I have a error code (which I cannot specify atm) but it basically tells me that problem TCU/ECU fuel pump communication. & I have already ruled out having a bad pump, every time I try to change the fuse the fuse gets shorted, so im thinking it could be a voltage converter. Which the Fuel Pump Control Module controls or then the auxiliary. Only Problem is when I go into the documents my WIS there's absolutely no information on the fuel pump module in terms of locating it or repairing. They have a diagram chart but it is unfindable. If anyone can provide me with pictures of where this could be it would be greatly appreciated
just checked for the part number and location via EPC and this is what i got:
Part number: A0009003505
Not much info to go about, but found a link for the W204 C300.... might be worth to see if ours is in the same spot.
here's the link:
