C300 cabriolet Trunk Lid Restriction.
2021 c300 Cab. Arrived 7/28/21 . 24 GLE 450e.
Hello, my owners manual says there is a setting for restricting the trunk from popping all the way up. It’s in the manual, but I don’t have a setting for it under Vehicle,Vehicle setting. Has anyone seen this setting? Thanks.
Did you ever figure this out? Same situation as you!
I mean that indeed successfully opens the trunk...
But I want to be able to set the trunk to only half-open as per the manual. Unfortunately, the setting as described in the manual doesn't appear to exist? Unless perhaps something is wrong with the trunk and the option disappears because something is broken?
PFL205.064 with M276.823 (Oil pump solenoid defeated)
