Must-have mods for 2021 c300 4MATIC (w/ amg line pkg)??
For power, I recommend a OBDII ECM Flash Tuner. This configuration allows you to quickly and easily restore your stock tune file when going to the dealer. This will leave a digital footprint in your ECM, but it's not easy to detect. In fact, I doubt most local dealers would have the digital forensics capabilities to detect this, it would most likely require the ECM to be escalated to MB engineering to detect. This seems like an unlikely scenario unless they have a specific need to go this far.
Something like this: https://mbworld.org/forums/c-class-w...oe-tuning.html
For throttle response, I recommend a throttle tuner. Modern drive-by-wire throttle systems are far from linear in their throttle inputs. Using a throttle tuner allows you to tune your throttle to respond like older cars used to behave, a closer 1:1 ratio between your foot and the throttle body, just like having a mechanical cable between the two. This will also help remove that stock throttle tuning feeling like you are pushing your foot into a bowl of mashed potatoes
I have a Pedal Commander and I can recommend it. It works well for me and my throttle response is much more linear now: https://pedalcommander.com/products/...-class-4th-gen
For handling, I think the simplest way to improve overall handling without going crazy with the suspension components and torsion bars, is to lower the center of gravity. Something like H&R springs. This will lower your ride height and will most likely have some affect on ride quality, so keep that in mind.
Also, if you don't care for the Eco stop/start feature and you're tired of hitting the Eco button to turn it off every time, this will solve that for you: https://www.midcityengineering.com/p...s-benz-ecopcm/
Good luck and enjoy!
