Need some help w205 c300 brake pad replace option
Old Aug 14, 2021 | 04:28 PM
Nico Candelario's Avatar
Veteran: Marine Corps
2022 E350 Benz
So I’m trying to change my rear brake pads. But my issues is I can’t get the workshop menu open. It’s take multiple try’s and finessing to get it but once I do. I click on brake pad replace and nothing happens I click it multiple times using the ok button and the brakes do not retract. It just keep going back to the brake pad replace menu Options…. Any idea guys ??? really trying to avoid the 500 bucks price Mercedes is charging.
but I need the pads to retracts. I tried to push the pistons back my self but it’s not gonna happen
Old Sep 4, 2021 | 09:38 AM
emielcvn's Avatar
S205 C200 2014
Did you already managed to solve this issue?
I struggled with it too but I forget to release the parkbrake before entering the service menu.
Old Sep 9, 2021 | 11:50 AM
C3004matidriver's Avatar
2015 C3004matic
I had this same problem when I tried to do mine the first time. It turned out that I had my door open so I couldn't retract the caliper. This turned out to be an expensive mistake. I took the caliper off anyway and the piston pushed all the way out, they do not compress back in with a brake pad compression tool. I called a Mercedes mechanic and he told me the only way to fix that is to replace the whole caliper, so I went $300 in the hole learning the hard way. Shut the driver's door and all other doors and try the workshop menu again. I had to try several times for it to work.
