C300 overheats
Old Sep 26, 2021 | 10:32 PM
Oscarw205's Avatar
c300 4matic
C300 overheats
Hello everyone I installed catless downpipe today and tuned it. After tune the car my CEL light came on, shop said to buy o2 sensor. Would that be the reason my car starts to overheat a bit? Would to know some feedback from anyone who’s staged 2 I’m a beginner at this
Old Sep 27, 2021 | 01:45 PM
stockbmw's Avatar
2018 C43
Curious, what do you think would happen when pollutants passes catless cat and existing o2 sensor pick this up and complains to the ECU? You would get a CEL.
When you install a catless dp, your tuner needs to disable the CEL from o2 sensor. Installing another o2 sensor will just trigger CEL. This is why lot of people upgrade to catted dp, but even then ECU is picky when O2 sensor gives it's readings. So you would need to tune it regardless.
Old Sep 28, 2021 | 09:39 AM
Andy74's Avatar
W205 2015
Your tunner should fix the issue. What if you bought another O2 sensor and the issue remains. Why the car overheating.
Old Sep 28, 2021 | 02:11 PM
Oscarw205's Avatar
c300 4matic
According to tuner my o2 sensor was scaled and not completely shut off. Appreciate your guys replies and help
