245 tires in front on C200 convertible
The best way to remove the guess work is to use the link below, enter what came on your car from the factory as your Existing Setup then enter what you are looking to change to as your New Setup. There's room to grow from factory specs, I'm running 8.5 wide wheels. Take measurements inside your wheel wells to make sure you have the clearance for what you want to do and adjust your new tire/wheel setup accordingly if needed. If you are on stock suspension, you should have plenty of clearance. It's safest to expand any increase in width outwards, especially on the front.
https://www.willtheyfit.com/
