Replacing brake pads
https://en.wikipedia.org/wiki/Electr...e_distribution
At the end of the day, you actually want the front and rear brakes to wear out at about the same time, so you can replace them together. While my rears went first, the fronts needed to be replaced less than a 1000 miles later.
But reality says rear pads are consumed first on MBs. As stated by @superswiss assist systems utilize the rear brakes, and it's possible although unknown whether or not MB uses a faster wearing pad material on the rears. Also we don't know with certainty the fluid proportioning front-to-rear that the master cylinder delivers. Furthermore, vehicles with electric parking brakes use the rear caliper pads. While small, the parking brake contributes to rear pad wear.
The rear pads are thinner than the fronts when new, and have a smaller surface area. So the volume of rear pad material is for sure less than the front pad.
Having said that, the general consensus is to replace brake pads once they are down to 3 mm. That's also typically when the wear sensor trips. During regular service they will measure your pads, so you get an idea of their wear level and can then decide. Rotors are a similar story. They have a minimum thickness that's typically about 2 mm less than new on the front and 1 mm less than new on the rear. The minimum thickness is typically stamped on the hat. A technician or you yourself can measure the thickness of the rotor and decide if you need to replace them. The rear rotors often last for two sets of pads, whereas the front rotors may need to be replaced with each new set of pads. In the past, rotors could also be turned to true them up and remove grooves etc, but today's rotors are as thin as possible to begin with to save weight. If the rotors are damaged like if they have grooves for example, then you need to replace them, too.
Dealerships don't want to deal with these nuances, though, so they will talk you in to replacing everything. If you want to be more specific have your brakes serviced by an indy. They can also assist you with possibly getting better aftermarket parts if you don't have anything specific in mind yourself.
Bought front and rear Akebono pads and replaced the fronts today. Wear sensor came on a couple weeks ago. The front pads were Mercedes brand that I believe were the second set along with new rotors when the dealer did the CPO work before I purchased. Pads had maybe 2 mm left. The rotors were in excellent shape with just a slight lip at the outer edge so I put the new pads on. Work well and are quiet and smooth.
On to the question. I started the backs and realized I did not have a 7 mm hex socket to remove the caliper so I went and got one. In checking the rear rotors, I see the wear holes in the rotor are almost gone. What's the consensus on replacing the rotor at this time. They are expensive as aftermarket in Canada and I haven't checked with Mercedes for their pricing.
The rears on my previous 2005 Audi A8 were also always first to go, by about 15-20,000 miles.
I've used Akebono pads on all my previous Euro cars to with good results.
