Smell of gasoline in the morning that goes away after 10 min of driving
Old Jan 5, 2022 | 09:58 AM
cheerful's Avatar
C300
Hi,
For the last 3 days, when I entered the car in the morning, there is a smell of gasoline. I checked around and did not see any leak. After driving for 10 min, the smell goes away.
I searched on internet. Most suggested it's some leak in the fuel system
What could I do to check?
thanks
Old Jan 5, 2022 | 10:47 AM
mikec35's Avatar
2016 C300 sedan
It's a known issue, leaks at the fuel hose fitting at the top of the engine where it connects to the fuel pump. Goes away when the engine warms up. I've attached a warranty extension originally posted on this forum by NDR.
I fixed mine the other day by replacing a defective or poorly installed clamp, I'll post pics of what I found/did later today in another thread so other DIY's can see if the same scenario applies to them. I'm out of the warranty window so I couldn't have the dealer remedy, if within the warranty window I would have certainly let them fix it.
File Type: pdf
Old Jan 5, 2022 | 05:49 PM
cheerful's Avatar
C300
Thank you!
Now I know I'm not driving a time bomb. Just called dealer to schedule a service. They said they will charge diagnostics. If confirmed, they will waive it and do it under warranty.
Old Jan 6, 2022 | 04:18 PM
rdr6765's Avatar
2000 Mercedes S430
I also got that extended warranty letter. Do i need to wait for the fuel hose to leak or will the dealership replace it before it happen. Thank you
Old Jan 8, 2022 | 05:06 PM
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
Don't wait for gas to potentially leak and start a fire. Have them evaluate and take the appropriate action. That way you are also covered legally if something related happens to your car.
(don't mention that last part to them)
