HI GUYS , I WAS ABOUT TO BUY A USED C200 2015 MODEL SO I DECIDED TO TAKE COMPREHENSIVE TEST TO CHECK VEHICLE PROBLEMS.BASED ON THE REPORT PLEASE HELP ME OUT TO MAKE DECISION TO BUY THIS CAR.
MINOR ENGINE OIL LEAK
ESP(Electronic Stability program -- ( 3 )
U0417FA
Data received from the Electric Parking Brake (EPB) were implausible.
B23AA1D Stored Event
The left brake calliper is faulty. The current value is out of the permissible range.
Stored
C100B77
The Electric Parking Brake (EPB) is faulty. The commanded position cannot be achieved. Stored Event
ISM(Shift module) -( 2)
P179A12
The Direct Select redundancy system is faulty. There is a short circuit to battery(+).
Pl 79DOO
Stored Event
The Direct Select redundancy system was activated.
Stored Event
PSD(Control module for panoramic sliding sunroof) -(1 )
U016887
Stored Event
Communication with the Electronic Ignition Switch (EIS/EZS) is faulty. The message is lost.
C200 2015 is a great car. They are built in Germany. I have one myself. AMG line. Did you test drive it? Did you feel anything wrong with it. Do you pictures of this car. Negotiate with your dealer to get these things solved. But i can tell that the C200 2015 is the Best or Nothing 😎
