Blown fuse/fuses and or rear battery?
used the 12+ inlet to the fuse panel back there and hooked my ground straight to the battery.
i then managed to slip and short between + and ground. rear camera/front driverside lumbar support/sound system/ rear window controls/radio signal no longer works. None of the fuses in the fusebox are blown though.
What exactly did you hook up the subwoofer to? What ground did you use (because it won't be battery as there isn't one in the back)?
It sounds to me like you might have shorted the whole rear sam in which case you'd need a replacement and coding of it, find a local MB specific shop or take it to a dealer as coding these cars isn't a trivial matter and to code the SAM to the specs of the car you'd need online SCN coding.
