C400: Coolant change procedure?
Does anyone have a simpler "drain and refill" technique?
If you go to the manufacturer website of pretty much any pink HOAT coolant, they specify 5 years or 150,000 miles, whichever comes first.
My wife's car has never had the coolant replaced and it's a 2015, so it's overdue, even though it has 93,000 miles.
shows 155k miles or 15 years for c class coolant change. 100k id prob consider changing mine since i want max performance, but im only at 62k so i have some time. The wifes ML has 110k and i dont plan on changing it.
G-40 coolant is a lot cheaper than a radiator or water pump.
I'll change mine at 5 years like the BEVO authorized fluid makers recommend. Here in Maryland our annual highest and lowest ambient temps have a +90F range so I'd prefer the additive pack and heat transfer/anti-freeze properties be at their optimal level.
