Rear Window
I just noticed that when I roll the rear window down on my ‘16 C300, I can still see a small sliver of window popping out where the curved arch is.. while it’s not a big deal, it’s a little strange I think. The window rolls down fine besides that issue. All three other windows completely disappear into the door panel. Should I be concerned?
Thanks!
Window not disappearing into door panel.
1. Close all doors
2. Have accessory mode on then CLOSE the windows
3. Once it Stops... Release and then pull the switch up like you normally CLOSE the windows for 15 seconds, make sure to pull it beyond resistance (in other words if you have not noticed already if you slightly pull it and then you pull it harder there is a click, that is called beyond resistance hold it at that position for 15 seconds and then release)
