Requesting help W205 headlamp programing
Old Sep 6, 2022 | 06:18 AM
kjmerctronics's Avatar
W205
Unhappy Requesting help W205 headlamp programing
hey guys
firstly i appreciate all your support .
i have a Mercedes w205 c200 2015 model , the vehicle was accident repaired on right side and the right head lamps was replaced .however the control units were not replaced but swapped from the old damaged unit.
now the right control unit is water damaged . i bought a brand new control unit and when i tried to adapt it i got to know that I don't see any of the QR cods present on the both headlamp units, it either removed or damaged in the accident .
i would really appreciate if some one could tell me if there is way if i could retrieve the original QR .
VIN WDD2050422F130681
headlamp part number a2059068801
water damaged control module part number A2229004505
Replacement Part number A2229000115(the only module which was available in my country please kindle let me know if this modules is compatible , The shop i purchaes told me that it fits and need to program and code )
i was able to program th new module and scn code it but still it wont get recognized by the vehicle
Again your suggestions and support are highly welcomed
Old Sep 7, 2022 | 12:24 AM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
In order to complete the job, you will need to program, scn code and teach in the new module. Teach in is pretty much entering the LED code. What did you use to program it and do the SCN??
Old Sep 7, 2022 | 01:02 AM
W205
Hello
Thanks for the response . my sd connect has a hardware issue its stuck at device booting. so i used Thinktool Master for programing and scn . The main problem is i dont have my LED codes available .
