2016 C300 Parking brake will NOT release automatically
I have a 2016 C300 and the parking brake will engage fine when parked. But, it will NOT automatically disengage when I start to drive the car - either in D or R. Every time, I have to manually pull the switch to disengage the parking brake. Anyone has similar issue or know what I need to do to get this fixed? As a friend of mine has a 2018 C300 and he can just start to drive and the parking brake will disengage automatically.
Any help will be appreciated. Cheers.
Received 3,817 Likes
2019 C63CS
Are you wearing your seatbelt? It will only automatically release if you click in the seatbelt before driving off.
C450 & 335i 740whp
I just tested. Even with seatbelt clicked in, the parking brake will NOT automatically disengage. Could it be some sensor that is prevent it from disengage?
Received 2,453 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
not sure if this makes a difference but try putting on your seat belt first then start the ignition/engine then put it in drive.
2019 C63CS
That doesn't make a difference for me, but the seatbelt has to be on before putting it in gear. The parking brake disengages automatically as soon as the transmission is put in gear, provided the seatbelt is on at that point.
2019 C63CS
OP it won't be easy to diagnose it unless it's throwing a code, get a MB specific reader and see if you have any stored/current codes.
2019 C63CS
MY15 didn't release the parking brake until you gave it enough gas, the gear display in the instrument cluster was also different compared to newer models (not talking about facelifted ones either), mine was completely transparent whereas MY17/18 had a semi-transparent gray rectangles around the PRDN letters so something was different in those models.
any solutions?
