Hello, I had the unfortunate issue of the 4 wires that go to the plug to the Distronic sensor getting ripped out and now I’m not sure which color wire goes to where and dont have access to a wire diagram or another C300 to see which wire goes to which pin location on the plug and am hoping someone can share pics of their in tact plug/wires or if you have access to the diagram which color wires go to which number pin on the plug itself. Ive included pics of the wires and the plug as well as the Distronic unit itself.
Hi did you have any luck with this? I have the exact same plug and colour wires but i'm unsure which way round the green ones go, I know they're the 2 in the middle just which way round! i've searched the internet looking for a plug that matches the wires but yours is the only one I have come across with the same colour wires and pin numbers used
Red/blue +12VDC, pin 1
Brown: -12VDC (ground), pin 8
If you have code 239 (Distronic Pro), other two wires are on pins #5 & 6.
If there is an code 440 (ussual cruse control), the pins are # 2 & 3.
Edit: I remember, the green pair is for simple CC (code 440), so pin 2-3.
