UPGRADE AUDIO
Old Dec 9, 2022 | 09:15 AM
nemesis1483's Avatar
2019 C300
UPGRADE AUDIO
Got a 2019 C300 but the system is basic. Door speakers and one center dash. If I wanted to upgrade to Burmester or one with subs, I’d it plug and play or do I need to have coding done. Also will I need different panels or will the current ones work?
thanks.
Old Dec 9, 2022 | 09:52 AM
Cosworth2000's Avatar
2022 E53 AMG
It's not plug and play. You'd have to install wiring and upgrade the full system since there is also an AMP under the passenger seat for the Burmester system.
Old Dec 9, 2022 | 10:30 AM
2019 C300
You wouldn’t know what type/ kind of wiring I would need would you?. I saw a used system for $500 I was going to get.
Old Dec 26, 2022 | 06:31 PM
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
My Burmester amp is in the trunk, passenger side, behind the trim.
Old Dec 26, 2022 | 06:34 PM
benzdude's Avatar
Top Answer: 1
Audiotec Fischer has all the cables, amp and speakers for a plug and play MB install.
https://www.audiotec-fischer.de/en/m...ors-harnesses/
Old Dec 27, 2022 | 03:40 PM
2019 C300
opened the center dash grill today and there's a speaker there and one under the steering wheel. are those suppose to be working or is that something the mercedes have to activate??
dash
under steering wheel
Old Dec 27, 2022 | 04:17 PM
PaulR7's Avatar
W205
The one in the centre of the dash is used solely for SOS function unless you have Burmester option in which case it's also used as a centre channel.
The one under the steering wheel is for beeps and chimes from the instrument cluster only and has no direct connection with any multimedia.
Old Dec 27, 2022 | 05:07 PM
2019 C300
here i was getting all excited for a bit better quality sound.
