Illuminated door sills are blinking…
Old Mar 8, 2023 | 12:39 PM
CargoluxPilot's Avatar
psasmjsdklkdsadsaads
Hi guys,
I just added the illuminated door sills on my 2019 S205 with using the following part numbers: control box A2229000308 and wiring harness A2138206702
The problem is both sides doesn’t stay illuminated all the time. They blink sometimes together, sometimes alternately…
Is there possibly any coding required to fix this?
I bought all of it new directly out of the original Mercedes store.
Normally they only should light up when you open the door in like a highlighting way. They should light up and dim down a bit as a welcome.
Thanks advance!
Dennis
Old Mar 8, 2023 | 03:48 PM
Cosworth2000's Avatar
2022 E53 AMG
Show a picture or video.
Old Mar 8, 2023 | 04:07 PM
There you go. I actually don’t get it. Is there something wrong with the control unit?
File Type: mov
Old Mar 9, 2023 | 12:41 PM
2022 E53 AMG
Did you connect it to the correct wires? It looks like you are connected a CAM wire which does not like to be connected to. Did the sill comes with the instructions? My car already came standard with the light sills and I replaced them with the AMG ones as these were suppose to be fitted.
Old Mar 9, 2023 | 02:29 PM
Did you connect it to the correct wires? It looks like you are connected a CAM wire which does not like to be connected to. Did the sill comes with the instructions? My car already came standard with the lite sills and I replaced them with the AMG ones as these were suppose to be fitted.
Everything is connected properly. I used the original WIS document.
Unfortunately I had to place a wiring harness because mine didn’t came with the illuminated door sills.
Old Mar 10, 2023 | 10:29 AM
2022 E53 AMG
Did you cut the end of the connector off and splice directly into two of the lines in the harness?
Old Mar 10, 2023 | 06:31 PM
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
Use a 12 volt tester or multi meter to test the wires when the door is opened, etc.
