Oil leak
Old Mar 14, 2023 | 09:46 AM
sc57rider's Avatar
W205
Oil leak
Hello
i recently found this oil leak in my 2014 C220d ,
one screw was loose so Im not sure if the oil is coming from the oil pan seal or from that screw itself, I attached a photo if you can determine source of leak.
another thing, any procedure for oil pan reseal for this model ? Thanks​
Old Mar 16, 2023 | 10:40 PM
Cosworth2000's Avatar
2022 E53 AMG
I think you solved your own problem. Just tighten, clean and see if there are any leaks. Also the pan uses a gasket and not a sealer.
Old Mar 16, 2023 | 11:00 PM
sc57rider's Avatar
W205
Thank you for reply, so a loose pan bolt can leak oil ? Because after tightening it i only found few dots of oil.
Old Mar 18, 2023 | 12:56 PM
2022 E53 AMG
The pan bolts have a pattern so the pan must be sitting flat and often some people over torque the bolts bending the pan. Yes, when you drive the oil moves back and forth and yes, the oil can drip pass the bolt.
