W205 C Class Internal Cabin Temperature Sensor
Old May 13, 2023 | 03:47 PM
g.matthews1987's Avatar
Mercedes C Class W205
Hi all - I have a 2015 W205 250d estate and have noticed that in order to feel comfortable inside the car, I need to set the climate control to around 27 degrees. I've run diagnostics at home on my icarsoft, and found that the internal temperature sensor was showing 30degrees when it clearly wasnt 30degrees inside the car. Has anyone else had this? The footwell airflow temperature sensors are working as they should. The climate control reponds independently on both sides of the car and produces cooler air when the temperature is lower. It just seems that the internal temperature sensor is off by a few degrees causing the need to set the climate control higher to feel comfortable. Has anyone else found this? Where is the internal cabin sensor located as I am wondering if i need to change it? The external temperature sensor is working as expected. Any help is much appreciated. Thanks
Old May 16, 2023 | 01:07 PM
Cosworth2000's Avatar
2022 E53 AMG
You are in the right place, I would just order a replacement. Also make sure you don't spray them with in cleaners. Also, they are are very easy to replace.
Old Aug 29, 2023 | 12:24 AM
frankonline's Avatar
C200 W205
Any update on this?
