Headlamps Light Malfunction
Old Aug 18, 2023 | 02:40 PM
mbco72's Avatar
2016 C300 4MATIC W205
Hello everyone, I am new to Mercedes however, on my C300 2016 and I attached pictures for reference, but I’m having a intermittent problem regardless, if it’s daytime or night time where my light switch is always in the auto position as that’s where I keep it at however, I get prompted on the dashboard to turn on headlamps, even though the switch is in the auto position, and as you can see in the pictures, it was daytime and my high beams and fog lights were switched on … Is this something fixable through software reset on the command center or any advice?
Old Aug 18, 2023 | 02:57 PM
Rogue-CLK's Avatar
2016 C300 4Matic
Manually turning your high beams off doesn’t do anything? It might be on the on position :/. Other than that not sure what could be the problem.
