winter tire help please
https://www.1010tires.com/Tires/Revi...tivtab=reviews
I usually check the tire rack test results or tyrereviews:
https://www.tirerack.com/tires/tests/testSearch.jsp
tyrereviews 2023-24 winter tire test:
For snow & ice, nordic winter tire test:
https://www.tire-reviews.com/Tyre-Te...-Tyre-Test.htm
As far as brands go, generally the top 3 (often most expensive) brands for winter tires are going to be Bridgestone (Blizzak), Michelin (X-ice) and Nokian (Hakkapeliitta) - not in any particular order. But if you look at any of those then they’ll most likely be over your goal of under $180/tire. Trying to keep that goal in mind then I would say the Falkens are decent, but maybe check out prices on Pirelli, Continental or Cooper first.
Honestly I find it worth the extra cost, most winter tires are going to last around 35,000 miles, but those are miles you aren’t putting on your all seasons. I would imagine you can find some Blizzaks for close to $200 each? Either way a decent set of winters are going to outperform any all season tires in the right conditions.
