Check Engine Code P0456 & P2188
For context, my car also throws pending (not current) code P2188 (System too rich at Idle Bank 1) every time I fuel up the car and also revs for about 3 seconds due to the leak.
I suspect that it might be the purge control valve solenoid but I cannot locate it in the engine bay and found no info about it online. I want to pull out and test the valve to see if it's the problem.
Could someone please provide a WIS guide for its replacement and location diagram?
