Removing front seats
Two questions: How do you remove the seat belt from the outside of the seat with the seat tensioner. Can I access the Torx screw and tensioner sensor connector only after I have lifted the seat or is it possible to remove the cover on the air bag section?
I think I have to leave the battery connected until I have removed all four base bolts because I have to move the seat backwards and forwards to access the bolts. However, before I disconnect any electrical plugs I believe I should disconnect the battery to prevent any possible code errors after fitting the new seats?
