W205 c250 cabriolet normal cluster to digital cluster
C 250 2018 cabriolet
Hello, I am thinking of changing my cluster to a digital cluster on my 2018 c250 cabriolet but I am unsure if I do so if everything would work as I have seen some reviews and some say that you won’t be able to see your tire pressure anymore and I need to make sure that all the safety messages are still going to work if I change to a Chinese branded digital cluster. Please if anyone has upgraded to a new cluster let me know your thoughts
Since you don't have a facelift (2019+) model, forget it. The digital chinese clusters are trash, and the only way to use the OEM digital dash is to either have a facelift (in which case, it requires a cable adapter and coding) or to retrofit NTG5.5 into the pre-facelift models, which is prohibitively expensive.
