harsh gear changes
Video:
https://youtube.com/shorts/3cSiGgwfLfs?si=QsIPZLWe_m_JnN0Z
One thing that does stick out is the fact that it takes off in 1st while in Comfort mode. What year and engine is your car? 7-speed or 9-speed? My understanding is that in Comfort mode most non-AMG models start in 2nd gear for a smoother more comfortable off the line start. 1st gear is only used in S and S+.
Thank you for your response. My car is 2.0 4 Matic 2016 W205 AMG line 7G tronic.
Gear change between 2nd and 3rd is very quick and you feel this when change happens in Comfort mode. In sport, S+ mode - when you press gas strong, you feel very uncomfortable gear changes 1-2-3. In other word, it feels like car stops during these gear changes, or reach very bad
Also, depending on the mileage, given the age, there is also a certain level of wear and tear. The transmission will wear over time, so that's another factor to consider. At some point, the clutch packs need to be replaced. I'm not really familiar with what the transmission maintenance schedule is for non-AMG models, but has the fluid ever been changed or have you at least checked the fluid level and the condition of the fluid? Have it checked for metal shavings, which would indicate that there's a mechanical issue internally.
