Problem with Adaptive Highbeam Assist Plus
Hey
Mercedes recently updated my high beam assist to the new high beams that stay on but block off incoming cars in contrast to shutting completely off if a car comes. I had a few issues with the old system so Mercedes gave me the upgrade for free under warranty. However yesterday when i tried it, I saw the lights blocking of the drivers, but most cars still flashed back at me, meaning that I flashed them with the high beams. Is there anyway to change back to the old high beam assist or fix the flashing other drivers. It works decent on highways but not on small country roads where jt should just turn off.
thanks
thanks
PFL205.064 with M276.823 (Oil pump solenoid defeated)
Hey
thanks
thanks
In the meantime, you could turn off adaptive high beam assist plus manually by switching the light switch on the bottom left from auto to the high beam area, that way it only turns on highbeam when you push the stalk forward and turns off when lifted back, there is no auto anymore in that mode.
https://encrypted-tbn0.gstatic.com/i...mUHAamRDhsMA&s
trigital (09-08-2024)
SPONSOR
WWW.BENZNINJA.COM
Hey
thanks
thanks
we can code that for you
and much more
