Air suspension problems
Old Oct 26, 2024 | 05:50 PM
Hannu_'s Avatar
Mercedes S205 250 Cdi 4-matic
Hello!
I will start of with my English writing is really not the best, but i will try and explain my problem the best i can and hope you understad me.
​​​​​​I have a 2015 Mercedes w205 with full airsuspension.
Yesterday when i was going to put it in comfort mode and the airsuspension interference came up on the dash.
The compressor will not start and the only fault code that i get in the icarsoft is "C157200 the correction time when filling is too long".
I have changed the compressor and relay about two years ago and have no leak in the suspension system so i dont think there is anything wrong with the compressor.
Is there any one out there that that have had the same problem?
Do this model of Mercedes have the same problem like the w212 had when the cables to the magnetic valve on the compressor corrodes and brakes?
And i have been searching but did not find anything about the same problem so sorry if this have been answered.
Old Oct 27, 2024 | 01:52 PM
Hannu_'s Avatar
I found the problem. It was the contact where the + cabel to the compressor is. It was full of corrosion and one pin was completely destroyed.
