Changing from runflats to Michelin Defender T+H
Old Feb 21, 2025 | 02:22 PM
smokingman43's Avatar
2016 C300 Luxury 4Matic
I know this subject has been beat to death, but I still can't find a straightforward answer. I have a 2016 C300 4matic that the previous owner changed from the stock run-flats to Michelin Defender T+H. The pressure on the fuel door says 32 PSI all around. The pressure on the driver door says Front 39, Rear 45. I assume neither is correct for the Defender T+H tires. I use a handheld tire gauge and currently set them at 32 PSI all around. The TPWS is way off and my MPG stinks. I drive conservatively in Comfort mode. I love the car but miss the simplicity and reliability of my Toyotas.
QUESTION: What PSI should I be using with non run flat tires?
Old Feb 21, 2025 | 04:24 PM
dmegeath's Avatar
GLC300, C 300
One way to resolve this ... set your tire pressure where you think it is best, then chalk mark a stripe across each tire's face of the tread (1" wide or so). Drive around normally for a mile or so - stop, roll the vehicle to see the chalk mark stripes. Worn early in the middle? Too much pressure. Worn early on the edges? Not enough pressure. I used this to get both my GLC and C300 set up.
Old Feb 21, 2025 | 04:43 PM
Great idea. Wish MB would give suggestions for non-runflats. They're so dam* particular about everything else. What PSI are you using?
